CarloSW2,
thanks for the props!
well it was my second effort!
I went for the 'sideway W" look so that the ends were 'spring loaded' and kinda gripped the top and the bottom of the opening. I am only using 1 very small bolt and nut to anchor it. Niether side has moved! Those lamps are 110watt extreme white. so they are aimed specificly NOT to blind oncoming drivers. I needed to be able to pivot them up and down also left and right.
again thanks for the kind words!
