Old 01-10-2010, 12:27 AM   #1 (permalink)
RH77
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
Hybrid Scangauge Settings and Data Logging
The Insight has a variety of feedback displays, but the SG could offer even more information...but what should be monitored?
Also, I have a datalogger to download data at a later time, more on that in a moment.
SG:
With "ECO-Assist" engaged, the gas pedal is non-linear, by which the output is muted and requires more travel than typical, so I assume TPS is out.
FWT is a must, without a stock visible gauge. The Tach is in good view, along with any MPG figures.
Any experience to lend?
Also, I have an OBD-II datalogging chip that records:
Vehicle speed, engine speed, throttle position, coolant temp, engine load, intake manifold pressure, air flow rate, intake air temp, timing advance, fuel pressure, fuel trim (long and short term, each in banks 1 and 2), O2 sensor voltages and battery voltage (some values are not used in specific vehicles -- it's hit-or-miss with a new car).
You can pick up to 4 variables with speed as the mandatory 5th option. Polling intervals are every 5 seconds.
To the best of my knowledge, the engine is a 1.3L "i-DSi" Honda LDA-Series (dual sequential ignition) engine with 2 spark plugs/cylinder, 2 valves/cyl, and a SOHC with the obvious hybrid stuff.
In your opinion, what is the best setup for feedback and/or data logging analysis?
Also, if there is a subset of data that you are curious to know include those too
Aside from obvious technique, it's really a square-one start for me with this setup...
Thanks!
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
