Old 01-11-2010, 10:41 PM   #50 (permalink)
moonmonkey
ecomonkey
silver clown - '02 toyota echo 2 door base
90 day: 47.16 mpg (US)
white ghost - '05 prius base
90 day: 47.53 mpg (US)
white pearl - '12 toyota prius base
Last 3: 45.69 mpg (US)
hey that guitarguy could you drill holes thru your allow rims and thrubolt the pan possibly using spacers of correct depth so as to not distort the pan when tightened? maybe do 4 at midpoint or 6 closer to the edges, it would only have a small screwhead or washer showing on the pan side, you could mount nuts on the innerside of the rim with epoxy? maybe wont work just theowin it out there.
