Data and Charts!
I took a trip to a store the other day and recorded both the 'to' and 'from' legs of the trip. I was mostly curious what the temperature readings and the Ah calculations (I haven't yet had an instrument to measure consumed Ah), but I thought that everyone might find the motor/battery amps interesting as well. These are the readouts from the serial output from the controller.
(Reminder: I'm running an impulse 9 with a 144v pack. Vehicle weight is about 3800 lb, and below is my heatsinking: Also, I have a copper heat spreader...)
Here's the 'To' leg. Everything is plotted vs. time. The jagged lines are the motor and battery amps and are referenced to the axis on the left. Both Ah and Temp are plotted on the right axis since they were in about the same range.
The trip above consisted of several miles of city driving, abut 10 miles of highway (at 55 mph, 3rd gear, about 5200 rpm), and another mile or so of city driving. Looking at the motor/battery amps, you can see the high amp accelerations from a standstill in the beginning and end, and also the lesser demanding (200 motor amps average) cruise on the highway in the middle .
Some observations:
The car sat in the shade beforehand so I think the initial temperature is a good indication of ambient (about 20C). The temperature rises pretty quick during the high amp accelerations while 'city' driving. Temps continue to rise gradually and I think they level off right at the end of the trip. This 'leveling off' is more apparent when looking at the return trip since the controller and heatsink start out already warm (see below).
Just before 16 min, I'm stuck at the offramp stoplight for over a minute. You can see the temperature fall quickly during that time.
This is the return trip along roughly the same route (a different city route at the end):
The acceleration onto the highway happens between minutes 3 and 4 where the battery amps rise to almost 250amps. The oscillations in motor amps from minutes 4-8 are from the freeway underpasses. At minute 8, i get stuck in some construction traffic and the driving is slower (40mph) and a little more erratic. The slight change in the slope of the Ah curve from these two sections shows the lower power requirement when driving slower.
The temp starts out at 30degC since it didnt' get a chance to cool down. Once it gets going though, it seems to level out pretty quickly around 38C, though the erratic driving kinda screws it up. Even so, after driving for 40 mins total, the high amp draws at the end causes peak temps just over 40C.
Thus, with this style driving, peak temps on the heat spreader seem to be about 20C over ambient. If thermal cutback doesn't come on until 75C, that should allow for operation in 55C ambient temperatures (which is ridiculously hot), or more strenuous operation in lower temperatures.
Also... this 27 mi trip consumed 45.3 Ah which is about 1.68 Ah/mi. Assuming an average battery voltage of 139V, that gives about 230 Wh/mi. I do pretty good on the freeway, but the heavy car eats amps in stop and go.
Paul, feel free to use these charts on your site if you want to. I vaguely remember someone asking about recorded runs to look at performance. I can share the raw data too...
