Old 01-12-2010, 04:13 PM   #12 (permalink)
Domman56
Tank - '76 Chevy El Camino Classic
90 day: 25.89 mpg (US)
Sabrina - '91 Mercedes Benz 190 E
90 day: 37.07 mpg (US)
Angel - '88 Mercedes-Benz 420SEL
Last 3: 23.01 mpg (US)
Quicksilver - '04 Mercedes-Benz CLK55 AMG Cabrio
Originally Posted by RH77 View Post
Agreed. A carefully tuned supercharger or turbo might help, but forced induction + larger displacement (with "fun" added to the equation) only spells more fuel.
The WT has the most potential of the Chevy lineup with stripped-down options (less weight), V-6, and I'm guessing a manual trans.
Modding and driving efficiently for highway speeds and using momentum to your advantage could yield results.
Stick with it and see what happens
RH77
That's what i meant a tuned turbo setup running between 3-6 Psi might help
Something like an STS rear turbo mount or another brand if it would work better . Don't really know the difference between them
By fun u just meant a little more power when you really wanted to open it up sorry if i was unclear about that
Tank:
(No actual EPA numbers for car just used F/E numbers when i first got it)
