Old 01-13-2010, 12:38 PM   #237 (permalink)
jackbauer
jackbauer's Avatar
Yes if both waveforms happen to be 180 degrees phase shifted. However with this design it will run on any ac voltage from 90v to 260v as long as the battery full charge voltage is lower than than 90% of the dc bus voltage at whatever ac input. eg rectified 240v ac gives about 320vdc so will charge from 32v to 288v. half that on a 120v ac input.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
