Old 01-09-2010, 10:54 AM   #231 (permalink)
jackbauer's Avatar
Water cooled resistor
ID:	5314   Click image for larger version
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
Old 01-09-2010, 10:32 PM   #232 (permalink)
bones007's Avatar
I love your water cooled resistor, so illusive - but so obvious. Super idea.
The Following User Says Thank You to bones007 For This Useful Post:
dave77 (01-11-2010)
Old 01-12-2010, 11:10 AM   #233 (permalink)
For another design, what about half wave rectify both sides of the 240v AC line so the negative output would be connected to neutral? (For 120v use, you could either half wave rectify it or revert to a bridge rectifier.)
If America manages to eliminate obesity, we would save as much fuel as if every American were to stop driving for three days every year. To be slender like Tiffany Yep is to be a real hypermiler...
Allie Moore and I have a combined carbon footprint much smaller than that of one average American...
Old 01-12-2010, 12:24 PM   #234 (permalink)
jackbauer's Avatar
One problem there is the very high ripple on the dc that results from half wave rectification
www.evbmw.com
Old 01-12-2010, 08:44 PM   #235 (permalink)
apowers's Avatar
I found this while looking for something else. But someone might find it useful.
The appl note for the 3906 seemed promising.
Battery Charge Management
Old 01-13-2010, 12:33 PM   #236 (permalink)
Half wave rectifying both sides of 240v is essentially full wave rectification.
Old 01-13-2010, 12:38 PM   #237 (permalink)
jackbauer's Avatar
Yes if both waveforms happen to be 180 degrees phase shifted. However with this design it will run on any ac voltage from 90v to 260v as long as the battery full charge voltage is lower than than 90% of the dc bus voltage at whatever ac input. eg rectified 240v ac gives about 320vdc so will charge from 32v to 288v. half that on a 120v ac input.
www.evbmw.com
Old 01-13-2010, 12:39 PM   #238 (permalink)
Use a buck/boost design that dynamically switches between buck and boost operation.
Old 01-13-2010, 12:42 PM   #239 (permalink)
jackbauer's Avatar
yep that can be done. as my battery is only 96v and single phase ac mains in Ireland is 240v its not required. However i will look at a buck-boost type design once i get the present unit up an running and work out the bugs.
www.evbmw.com
Old 01-24-2010, 12:55 PM   #240 (permalink)
jackbauer's Avatar
Well with the car back together i decided to finish up the charger. Just some metalwork. Naturally i was short one bolt!!! Will hopefully be installing the charger and batteries this week. By the way my apologies to the op i didnt mean to hijack the thread!
ID:	5463   Click image for larger version
ID:	5464   Click image for larger version
ID:	5465   Click image for larger version
ID:	5466   Click image for larger version
www.evbmw.com
The Following User Says Thank You to jackbauer For This Useful Post:
adamj12b (01-25-2010)
ev charger
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1056 12-14-2024 01:21 AM
Any interest in developing an open source fuel economy gauge/computer? MetroMPG OpenGauge / MPGuino FE computer 182 06-25-2010 08:00 AM
Open source PCB design dcb OpenGauge / MPGuino FE computer 39 04-25-2010 10:18 PM
Open Source electric conversion information bennelson Fossil Fuel Free 8 02-14-2009 12:23 PM
Open Source LEV Controller FrankG Alternative Transportation 1 03-24-2008 04:10 AM
