Old 01-13-2010, 12:42 PM   #239 (permalink)
jackbauer
jackbauer's Avatar
yep that can be done. as my battery is only 96v and single phase ac mains in Ireland is 240v its not required. However i will look at a buck-boost type design once i get the present unit up an running and work out the bugs.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
