Old 01-14-2010, 12:39 PM   #32 (permalink)
winkosmosis
Yes,but isn't there an inter-spacial distance in between them ( like individual tread blocks on a tire ),where you'd be relying solely on the thickness of the sheet for it's strength?
Some diamond plate is like that but some has interlocking ridges. Even if you are depending on the thickness of the sheet between the ridges it would still be more rigid, just like those skid plates with the dimple die holes.
Complete interlock
Even better
The Following User Says Thank You to winkosmosis For This Useful Post:
aerohead (01-14-2010)
