Old 01-14-2010, 01:53 AM   #31 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
Here's my 4'x8' luan sheet under my T-100 truck...not bad fer a $10 sheet.
It won't compare to Aerohead's T-100 though...
Old 01-14-2010, 12:39 PM   #32 (permalink)
Yes,but isn't there an inter-spacial distance in between them ( like individual tread blocks on a tire ),where you'd be relying solely on the thickness of the sheet for it's strength?
Some diamond plate is like that but some has interlocking ridges. Even if you are depending on the thickness of the sheet between the ridges it would still be more rigid, just like those skid plates with the dimple die holes.
Complete interlock
Even better
The Following User Says Thank You to winkosmosis For This Useful Post:
aerohead (01-14-2010)
Old 01-14-2010, 04:35 PM   #33 (permalink)
more rigid
Complete interlock
Even better
Gotcha! A picture ISSSSSSSSSSS worth a thousand words! Both the plating you show WOULD be stiffer from the inter-weaving of the raised portions.
Appreciate the heads up!
Honda Accord Factory Belly Pan/rear diffuser EVDRVR Aerodynamics 8 09-07-2015 12:00 AM
rear diffuser fabrio. Aerodynamics 30 05-17-2010 01:36 AM
rear diffuser build thread LeanBurninating Aerodynamics 24 06-06-2009 09:32 PM
Front plate alternatives pasadena_commut Aerodynamics 8 07-12-2008 11:30 PM
Front License Plate Mounting Harry6 Aerodynamics 6 04-01-2008 09:56 PM
