01-14-2010, 01:25 PM
#67 (permalink)
If the dump controller won't do what you want, don't forget that since you have a full Arduino, you should also be able to get one of the cheap, stripped down kits where you program the chip on the full board and swap it into the cheap board to run whatever stuff you need.
