Old 01-14-2010, 04:35 PM   #33 (permalink)
aerohead
more rigid
Originally Posted by winkosmosis View Post
Some diamond plate is like that but some has interlocking ridges. Even if you are depending on the thickness of the sheet between the ridges it would still be more rigid, just like those skid plates with the dimple die holes.
Complete interlock
Even better
Gotcha! A picture ISSSSSSSSSSS worth a thousand words! Both the plating you show WOULD be stiffer from the inter-weaving of the raised portions.
Appreciate the heads up!
