Originally Posted by MetroMPG
Rick, that's cool. How did you do that?
I rigged this up about a year ago...
First, I opened the housing of the cruise-control servo assembly. Inside is essentially what looks like the throttle-body arm attached to an electric servo. It has a metal stop on each end for zero throttle input, and maximum cruise throttle input.
I found if you wedge a hex-wrench in there, then the arm rotates and stops depending on the size of the wrench. With manual rotation and SG monitoring, I got it to limit the cruise to 21% TPS by trying a variety of wrench sizes. Then the whole works was clamped together.
For safety purposes, nothing restricts the 0-21% movement of the cog -- so it can still be de-activated by pressing the brake, etc.
It's great for longer highway trips that become tiresome.
BTW, great numbers Larry, and Welcome
I had the pleasure of renting about 4 Priuses lately and I absolutely love them! I have to admit that actually they're fun to drive from the way they operate to handling, etc. I drove on some twisty mountain roads and found that the response and handling is surprising agile and forgiving -- more like a small sportscar, if I could be so bold. Great for those downhill charge-ups
RH77
