Old 01-15-2010, 10:30 PM   #11 (permalink)
cfg83
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
Hello -
I swapped out the furniture rubber feet for faucet washers. The washers are about 1/8" shorter, but that made the bolt stick out more (as seen in the Before insert) :
Sooooo, I just added a nut to the original bolt on the *inside* of the plastic lug nuts. This shortened the bolt. This got me back to my original situation, where the bolts stick out about 3/8" from the cover :
(You are seeing a washer with rubber backing, a lock washer, and the nut. The number of lines you see on this plate are 40 total. That is divisible by 4 and 5, so the lines can be used as guides for 4 and 5 lug wheels)
I am ok with the 3/8" protrusion because I reduced my total protrusion by 1/8". Now my wheel covers are pretty much flush to the tire :
Here is a front view of same :
I think I can get the mounting bolts a little more flush, maybe 1/8" more. For the next wheel I think I will try a "reverse bolt" version where I put the nut *inside* the plastic lug nut. I just need to find the parts to keep the nut centered. I also need to make sure it doesn't spin around when I am attaching the bolt. Maybe all I need to do is blob some sillycone onto it. We'll see.
I did just realize that the plastic tray can't be UV resistant. That implies I should paint it with a UV protective spray paint. In that case I would probably paint it white so that it doesn't suffer the sun's harmful rays.
CarloSW2
American Solar Energy Society
The Following User Says Thank You to cfg83 For This Useful Post:
aerohead (03-08-2011)
