Old 01-17-2010, 01:50 AM   #19 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
Carlos -
Ironically, I haven't done any of those things with my van, and I'm getting around to taking it off the road now, due to damage from it being backed into. We'll see how everything works out w/ the insurance company as to whether or not I get to do any work on it, but I guess the plan is RWD, manual trans, diesel, aero mods, and 1/2 ton suspension for now.
I like the wheel covers, though. They're great, and the blackout is awesome, especially if you pay close attention to the little bit of silver that shows around the edges... it's a silver ring floating down the road!
I can't think of the name of the plastic stuff that my plates were made of, but it was crap... my Father knows what it is... you couldn't even stick it in the nuker-wave, or it would literally explode into a few pieces, but I think those trays are made of a similar material, by the look.
How about just using some plastic epoxy and filling the plastic nut's hex head, then drilling and threading the hardened plastic?
That would allow you to use normal pan-head or machine screws, which could be put in and removed with a simple screwdriver (or dime) and would sit mostly flush.
BTW - your wheel pattern is 100mm, it's metric.
Looking forward to seeing how they turn out, and where it leads!
