Thread
Paul & Sabrina's cheap DIY 144v motor controller
01-17-2010, 08:41 AM
2871
permalink
wakinyantanka
Custom EV Builder...
Originally Posted by
edown
Paul, I just wanted to show you yet another configuration for the power section. The mosfets are only rated at 75 amps, 280 volts, which is why there are so many of them; but at $1.35 each, I thought I would give it a try. One advantage of this configuration is that there are no thermal pads under the diodes or the mosfets, and I have 20 square inches of contact with the heat sinks.
Very nice work.
What do you calculate your peak output at?
Are you using more than one driver for the mosfets?
wakinyantanka
View Public Profile
Send a private message to wakinyantanka
Find More Posts by wakinyantanka
