Old 01-08-2010, 11:24 AM   #2861 (permalink)
PaulH
MPaulHolmes's Avatar
Air cooled. I'm probably 1-2 work days away from ordering pcbs, in a perfect world where I actually had 1-2 days to work on it, and then had the money to order the pcb. haha. This is a picture of the layout with one high side and one low side driver:
I need to change the spacing for the 3 different ground planes, but it's just a rough draft. I need to add 1 more driver to the high side and 1 more to the low side. Synchronous rectification is really really touchy because of the possibility of high and low side being turned on at the same time by accident (even a little glitch I think could short the mosfets). I was thinking of using 4 isolated 12v supplies. One for each driver. Fran was telling me about a different tricky way that simulates isolation using some small inductors and capacitors as the pseudo isolated power supplies, so I might try that instead, but I'm a brute force, totally inelegant sort of guy. haha. (it's true)
kits and boards
Old 01-08-2010, 11:48 AM   #2862 (permalink)
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
I have a couple of heatsinks that I pulled off a junkyard forklift battery charger.
They have large fins, but ALSO two holes running the long direction through the base of the heatsink.
These heatsinks could be used for aircooling, but would be a snap for converting to liquid-cooling as well!
If anyone is planning a High-AMP version of the controller, keep an eye for for heatsinks that could potentially be liquid-cooled as well.
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Old 01-08-2010, 02:54 PM   #2863 (permalink)
Custom EV Builder...
Nice work Paul. Adam and I briefly talked about a similar set up but I have zero time. I'm still trying to finish the composite structure for the "Orion". Plus all the projects at home.
Old 01-08-2010, 05:32 PM   #2864 (permalink)
AC-DC enthusiast
mrbigh's Avatar
Dual-PWR PHEV - '04 Toyota Prius
Kopper - '79 Bradley Bradley GT-II
I need to add 1 more driver to the high side and 1 more to the low side. Synchronous rectification is really really touchy because of the possibility of high and low side being turned on at the same time by accident (even a little glitch I think could short the mosfets).....
..... I was thinking of using 4 isolated 12v supplies. One for each driver. Fran was telling me about a different tricky way that simulates isolation using some small inductors and capacitors as the pseudo isolated power supplies, so I might try that instead, but I'm a brute force, totally inelegant sort of guy. haha. (it's true)
If I'm not wrong, there are isolated -/+ regulated power supplies modules similar to the ones that are being in use now.
Can you please list the added improvements to this upgraded PCB revision?.
Some suggestions for the "To do List" that would make a great motor controller.
-Would it be implemented any temperature sensor readings, also through its serial port?, like a controller's temperature cut back and an additional motor temperature input sensor, (both in one OP AMP chip circuit) .
-Current sensor reading on DC (battery side) input? End user optional decision and budget.
-Selection of throttle input by resistive and/or hall effect.
Prius Absolutum Dominium . ..........KOPPER
PHEV conversion since Dec 2006.. . .... .Future EV
. . . . . . . .CALCars # 27. . . . . . . . . . ..on the works now !!
Old 01-09-2010, 04:17 AM   #2865 (permalink)
jackbauer's Avatar
Positive and negative dc dc converters are readily available. I'm using one in the charger. I'd be looking at putting a serious negative voltage on the gate of the the device your turning off. Just pulling it to ground won't be enough. my 2c.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
Old 01-09-2010, 11:14 PM   #2866 (permalink)
EVVette - '71 Chevy Corvette Coupe
As of right now, we are able to compute the battery amps inside the micro controller very accurately. This how we limit the battery amps. In my testing of the battery amps limit testing last week, I was commanding a 20A limit and with my fluke meter, I was showing 21A on the battery terminals. I also set it to 100A limit and then showed 100.5A on the fluke meter!! with both of those, its about 1% error. Not bad for doing it based of motor current!!
So adding an additional current sensor and circuitry needed to measure battery amps when its not really needed would just end up costing about $30 more when the feature is already in place for free.
EDIT: Ive attached a picture of the Fluke meter with the reading. Look at the computer in the background, You can see Battery_Amps_Limit = 100 and the meter says -100.5 because I had it on backwards. LOL. Enjoy!!
-Adam
www.EVVette.com - 1971 Corvette Coupe Conversion to all Electric!
www.AdamBrunette.com - Machining, CNC, Robotics and Electronics.
You can download RTD Explorer for the Cougar controllers at www.EVVette.com
The Following User Says Thank You to adamj12b For This Useful Post:
deodeo (03-22-2012)
Old 01-09-2010, 11:39 PM   #2867 (permalink)
AC-DC enthusiast
mrbigh's Avatar
Great!!!!
One wish of the "TO DO LIST" is granted with all the hardware built in Paul''s controller and Adam's tinkering with out extra expenses.
Old 01-12-2010, 01:04 PM   #2868 (permalink)
Joe
Data and Charts!
I took a trip to a store the other day and recorded both the 'to' and 'from' legs of the trip. I was mostly curious what the temperature readings and the Ah calculations (I haven't yet had an instrument to measure consumed Ah), but I thought that everyone might find the motor/battery amps interesting as well. These are the readouts from the serial output from the controller.
(Reminder: I'm running an impulse 9 with a 144v pack. Vehicle weight is about 3800 lb, and below is my heatsinking: Also, I have a copper heat spreader...)
Here's the 'To' leg. Everything is plotted vs. time. The jagged lines are the motor and battery amps and are referenced to the axis on the left. Both Ah and Temp are plotted on the right axis since they were in about the same range.
The trip above consisted of several miles of city driving, abut 10 miles of highway (at 55 mph, 3rd gear, about 5200 rpm), and another mile or so of city driving. Looking at the motor/battery amps, you can see the high amp accelerations from a standstill in the beginning and end, and also the lesser demanding (200 motor amps average) cruise on the highway in the middle .
Some observations:
The car sat in the shade beforehand so I think the initial temperature is a good indication of ambient (about 20C). The temperature rises pretty quick during the high amp accelerations while 'city' driving. Temps continue to rise gradually and I think they level off right at the end of the trip. This 'leveling off' is more apparent when looking at the return trip since the controller and heatsink start out already warm (see below).
Just before 16 min, I'm stuck at the offramp stoplight for over a minute. You can see the temperature fall quickly during that time.
This is the return trip along roughly the same route (a different city route at the end):
The acceleration onto the highway happens between minutes 3 and 4 where the battery amps rise to almost 250amps. The oscillations in motor amps from minutes 4-8 are from the freeway underpasses. At minute 8, i get stuck in some construction traffic and the driving is slower (40mph) and a little more erratic. The slight change in the slope of the Ah curve from these two sections shows the lower power requirement when driving slower.
The temp starts out at 30degC since it didnt' get a chance to cool down. Once it gets going though, it seems to level out pretty quickly around 38C, though the erratic driving kinda screws it up. Even so, after driving for 40 mins total, the high amp draws at the end causes peak temps just over 40C.
Thus, with this style driving, peak temps on the heat spreader seem to be about 20C over ambient. If thermal cutback doesn't come on until 75C, that should allow for operation in 55C ambient temperatures (which is ridiculously hot), or more strenuous operation in lower temperatures.
Also... this 27 mi trip consumed 45.3 Ah which is about 1.68 Ah/mi. Assuming an average battery voltage of 139V, that gives about 230 Wh/mi. I do pretty good on the freeway, but the heavy car eats amps in stop and go.
Paul, feel free to use these charts on your site if you want to. I vaguely remember someone asking about recorded runs to look at performance. I can share the raw data too...
ReVolt AZ testing thread:
http://ecomodder.com/forum/showthrea...ting-9325.html
The Following 2 Users Say Thank You to jyanof For This Useful Post:
MPaulHolmes (01-12-2010), mpgmike (01-14-2022)
Old 01-16-2010, 07:27 PM   #2869 (permalink)
EvEagle
Paul, I just wanted to show you yet another configuration for the power section. The mosfets are only rated at 75 amps, 280 volts, which is why there are so many of them; but at $1.35 each, I thought I would give it a try. One advantage of this configuration is that there are no thermal pads under the diodes or the mosfets, and I have 20 square inches of contact with the heat sinks.
The Following 2 Users Say Thank You to edown For This Useful Post:
deodeo (03-22-2012), mpgmike (01-14-2022)
Old 01-16-2010, 07:35 PM   #2870 (permalink)
EvEagle
The bottom side.
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 3431 05-04-2022 05:43 PM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 04:10 PM
