I thought about some kind of springs. Perhaps leave the bolts proud and have some wavy washers or springs so it can push off if contact is made. Your idea is a bit more steathy but the leverage effect would require lighter springs. I just wish it were easy to put a lip on them or bend out a lip.
I also thought of using some neoprene weather stripping which would seal the gap and create some padding there in case of deflections but I doubt the adhesive would last. Cheap to try though. It would allow a larger gap too without sacrificing aero.
I just thought of a possible way of slightly flattening/flaring them which may or may not work. They are a bit "deep" and may add to the frontal area. They could be sandwiched and compressed evenly. They might buckle though. Hmmm.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
