Old 01-18-2010, 10:02 PM   #86 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
Originally Posted by bennelson View Post
The 300D flywheel is heavier, though, isn't it? How would that effect engine performance?
I am also not completely clear on a flywheel being balanced to the engine or not.
Actually, I believe they're the same part, but even if it's a little heavier, it will just rev slightly slower. The difference won't be much, if any (~3lbs max).
The balance thing, you just look for a nick mark on each piece, and line them up when you mount the flywheel to the crank. There should be a nick on the crank already, and whatever flywheel you get should also have a nick on it. If either doesn't, you don't have to worry about it.
