Old 01-12-2010, 07:42 PM   #81 (permalink)
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
Any progress with the tranny swap?
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
Old 01-18-2010, 09:07 PM   #82 (permalink)
Big Dave's Avatar
Any joy on that bellhousing yet?
4" Slam
Old 01-18-2010, 09:37 PM   #83 (permalink)
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
I haven't had much time to dedicate to the project lately.
The next thing I need a a MANUAL flywheel from a 240D engine - that way, I can connect the engine to a manual transmission.
I really don't need the specific transmission to go with it, but the right flywheel is a must.
If I can't find one of those flywheels, getting one made is a possibility as well, but that sounds pricey fast!
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Old 01-18-2010, 09:44 PM   #84 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
You can use one from a 300D/TD engine as well.
Old 01-18-2010, 09:58 PM   #85 (permalink)
EV test pilot
bennelson's Avatar
S10 - '95 Chevy S10
The 300D flywheel is heavier, though, isn't it? How would that effect engine performance?
I am also not completely clear on a flywheel being balanced to the engine or not.
My YouTube Videos
Old 01-18-2010, 10:02 PM   #86 (permalink)
Actually, I believe they're the same part, but even if it's a little heavier, it will just rev slightly slower. The difference won't be much, if any (~3lbs max).
The balance thing, you just look for a nick mark on each piece, and line them up when you mount the flywheel to the crank. There should be a nick on the crank already, and whatever flywheel you get should also have a nick on it. If either doesn't, you don't have to worry about it.
Old 01-19-2010, 01:41 PM   #87 (permalink)
Big Dave's Avatar
Check out PeachParts - Mercedes Parts & Tech Info
They have lines of supply for old Benz parts.
4" Slam
Old 01-19-2010, 04:02 PM   #88 (permalink)
LOL - that's the 2nd or 3rd time that link has been posted.
I'm a member on their forums... same name.
Old 01-19-2010, 05:59 PM   #89 (permalink)
Big Dave's Avatar
Try Transmission Adapters. They have an off-the-shelf adapter for attaching a OM617 to a 700R4. Why? I don't know, but obviously they are familiar with DIN bellhousings.
4" Slam
Old 01-24-2010, 01:42 PM   #90 (permalink)
Make Sure you keep track of all your expenses!! This Is something I've been thinking of doing for a while, but never had a clear idea. I joined this forum when i saw this thread and would REALLY like to see your progress till the end, and also how much the project cost you in all! Loving the videos as well.
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 158 01-12-2013 12:59 PM
A Pickup Truck Project Big Dave EcoModding Central 47 09-12-2011 12:42 PM
Aeromoding my truck ('95 Chevy S10 pickup) bennelson Aerodynamics 42 12-17-2010 07:28 PM
The Classic: my 1969 Chevy CST/10 resto project texanidiot25 The Lounge 5 04-26-2010 02:22 PM
Budget chevy lumina project. ihatejoefitz Introductions 4 04-19-2008 07:41 PM
