Old 01-19-2010, 10:53 AM   #17 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
The question is, is it worth going to a wider LRR tire, or skinnier regular tire?
You could estimate the trade-off, but only if you know the difference in rolling resistance between the two tires you're comparing.
The negative impact of increasing tire width on Cd has been quantified on numerous vehicles.
See: http://ecomodder.com/forum/showthrea...g-cd-7475.html
Don't forget frontal area also increases slightly with wider tires.
If you know the values, you can plug them in to the aerodynamic drag / rolling resistance tool: http://ecomodder.com/forum/tool-aero...resistance.php
