92 civic vx vss?
Setting up MPGuino and cant seem to get vss signal. I tapped from the unit itself. With the ignition on its 12 v at rest. According to my haines manual its a blue and yellow wire. I get no no speed measurement at all. checked and rechecked the wires. Not sure what I did wrong. I guess I could tap from the ECU, but at the time the sensor seemed easier. The Injector connection seems to work just fine.
