Got it working seems that I was on the 12v supply to the vss. I read the schematic wrong as the blue/yellow wire output to VSS not the signal back to the ECU. Now on to the calibration. Thanks for your help.
By the way the signal is fine out at the sensor. Maybe the vss at the instrument panel is 0-5v but its not that way at the sensor.
