Old 01-22-2010, 04:20 PM   #6 (permalink)
busypaws
Location: Live in Tucson AZ, work and car now in Detroit
Protege - '97 Mazda Protege DX
90 day: 46.42 mpg (US)
Removed mine in a 97 Protege. Total weight 47 lbs. I did go and have it pumped dry at service station ($20) to be enviromentally correct. It was on the same belt as PS and I removed it as well. (30lbs saved). When you remove the evaporator behind the glove box make sure you put the plastic box back together so you have fully functioning air handling system. Now I want to grind off the extra pully on the crankshaft pully to remove a pound or two of rotating mass.
