Old 01-21-2010, 08:20 AM   #1 (permalink)
White118's Avatar
Bandit - '97 Geo Metro
Taking out my AC system?
The AC does not work in my geo and I don't use it anyways I'm a 2 /55 guy so I'm thinking for taking out the compressor and all the lines and the condenser out to lighten up the vehicle and make more room under the hod.
-Matt
Old 01-21-2010, 09:47 AM   #2 (permalink)
Send a message via MSN to markweatherill
I had a small Toyota with non-functioning A/C. I removed the compressor, condensor and pipework and it certainly made more room but didn't improve mpg at all noticeably.
Old 01-21-2010, 09:50 AM   #3 (permalink)
McTimson's Avatar
Maverick - '22 Ford Maverick XLT
90 day: 37.19 mpg (US)
Go for it. It won't save much weight, but if it's easy enough in the Geo, then I say go for it.
Does your AC run on a separate belt, or does it run with power steering, or an alternator? If it's separate, you can just get rid of the belt and forget about it, otherwise you'll have to find the accessory belt for the non-AC version of your car.
The compressor will be the heaviest thing, but only about 15lbs or so. The lines weigh virtually nothing, and the condenser and evaporator are pretty light as well. It will make the engine bay look cleaner though, without the AC lines going through it. I suppose it helps with cooling the radiator as well, since it won't have the condenser in front of it.
Overall, I think I figured it was about 25-30lbs saved. So it's really not much, but you're also eliminating one of the belts from the engine, so that can only help.
Before you do it, get the AC discharged at a shop, to remove the freon inside the lines.
Old 01-21-2010, 12:07 PM   #4 (permalink)
White118's Avatar
The belt is off now, it had its own belt so no worries there. I don't think it has any freon in it but if there is I plan on taking it to a shop and heaving it sucked out. Then it will be to the drawing board to build a closed front and new clip.
-Matt
Old 01-21-2010, 09:52 PM   #5 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
You will save only about 20 lbs overall removing the A/C parts minus the evaporator (behind dash) so I would probably just pull the A/C compressor and whatever is under the hood just to open up the engine compartment some.
GeoMetroforum.com - got mpg?
Old 01-22-2010, 04:20 PM   #6 (permalink)
Location: Live in Tucson AZ, work and car now in Detroit
Protege - '97 Mazda Protege DX
90 day: 46.42 mpg (US)
Removed mine in a 97 Protege. Total weight 47 lbs. I did go and have it pumped dry at service station ($20) to be enviromentally correct. It was on the same belt as PS and I removed it as well. (30lbs saved). When you remove the evaporator behind the glove box make sure you put the plastic box back together so you have fully functioning air handling system. Now I want to grind off the extra pully on the crankshaft pully to remove a pound or two of rotating mass.
Old 01-22-2010, 07:27 PM   #7 (permalink)
White118's Avatar
Grid off the pulley, use a puller. I will be taking out the a/c system this weekend and try to get some pictures up. thanks for the advise.
-Matt
Old 01-23-2010, 12:12 AM   #8 (permalink)
89HF's Avatar
MightyMouse - '89 Honda CRX HF
90 day: 53.61 mpg (US)
hey, 20 lbs is 20 lbs. On a Geo that's over 1% of the total weight of the car. Think about how much our fuel efficiency might go up if we all went on a diet! For that matter, it would be interesting to estimate the annual fuel savings of our nation if we reduced obesity...maybe Obama should put that in his energy plan, state of the union coming up
Old 01-23-2010, 02:25 AM   #9 (permalink)
recession proof rebel
k.civic.f4i's Avatar
haha. i agree
how to.....
http://ecomodder.com/forum/showthrea...cks-11998.html
http://ecomodder.com/forum/showthrea...how-12301.html
true wealth comes from good health and wise ways
Old 01-23-2010, 10:14 AM   #10 (permalink)
White118's Avatar
I don't think we would get good numbers out of people weighing less. Even tho Obama has a magic wand for everything he would have to stop enabling the people that collect of the system and sit at home and eat our tax dollars in food stamps and welfare. All the weight you and I loose will be gained by them, so it would be a wash.
New CVT transmission electric-assist with electric assist Ptero Fossil Fuel Free 2 09-23-2010 10:41 PM
DC Generators to power electric cars. overover Forum News & Feedback 6 11-08-2009 06:12 PM
NEWS: KERS flywheel system to power large trucks? MetroMPG EcoModding Central 10 10-10-2009 05:23 PM
AC vs DC for DIY MazdaMatt Fossil Fuel Free 15 03-06-2009 09:33 AM
