Old 01-24-2010, 04:28 PM   #31 (permalink)
orange4boy
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
Photos when I'm next under there. Can you handle the suspense? It's mounted below the inverter coolant pump and the return hose splices into the radiator-bound transaxle coolant hose. The mounting bracket is pushed through the "towing hole". It's a tight fit but not too bad.
The cold line comes from the modded coolant drain plug and passes under the oil pan. I might re-route this one later and make it a hard line. I should have marked the drain plug when tightened before soldering the 90˚ on the end. I had to improvise a gasket there so it would point in the right direction. A union would be better there.
45 seconds for cat ignition? I will have to make sure I wait for that before driving up the hill. Cat preheat? My garage is going to look like the Apollo launch pad soon.
Is there a temp sensor in the cat or do they use the oxy sensor to check for cat temp?
The "plug-in lite" would be great for me because it would warm the battery and give me enough juice to possibly drive up my driveway on EV without loading the engine while the warmup is underway. Who makes a cheap charger? Ha ha.
I'm hoping to be able to be in stage 4 before that though.
The slope coming home does give me a bit of a boost but I'm usually under 60% on return.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
