Old 01-24-2010, 06:06 PM   #2883 (permalink)
etlaare
Couldn't resist sharing my little milestone with you of the controller board connected to an igbt today. Still some work left to do though..
http://www.etlaare.demon.nl/throttle2.wmv
And for what it is worth I would like to share some funny experience with using a USB-RS232 converter with a laptop running windows to connect it to the RTD-Explorer. I had to do that as the new laptop had no serial port anymore.
The first time I connected it, it worked fine, the driver used COM4 which information can be retrieved in the device manager. Later however it did not connect properly anymore. It took me a while to figure out that when my cellphone is nearby, the laptop establishes a bluetooth connection who's drivers claim COM4, COM5, COM6 and COM7.
Hence, the RTD-Explorer should suddenly connect through COM8 ....
Just in case you run into connection problems one day... just didge your bluetooth cellphone (preferably send it to me ....)
Ed
The Following User Says Thank You to etlaare For This Useful Post:
MPaulHolmes (01-24-2010)
