Well, Davis is working with me to setup the data logger -- it just won't remain "alive" to collect data. It should work with all 2010's, but a patch might be required, or specific protocol.
The SG is now installed. In temps colder than 35F, it has been hard to keep the coolant temp higher than 175F (even without the cabin heater). IATs are in the 50's. Last night, I removed the snorkel and blocked the vent from the grille. The intake simply draws from behind the radiator. Results pending...
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
 _
 _
