Originally Posted by drbobwoolery
What's wrong with the PNP level shifter in post 24?
Worked on the bench, and not in the car.
Originally Posted by dennyt
...Any recent developments, or should I dive in with this op amp circuit?
If it is peak and hold, try the opto isolator circuit.
http://ecomodder.com/forum/showthrea...tml#post106855
how many ohms is the injector when unplugged? If it is low (< 7 ohms?) it is likely peak and hold.
