Old 05-28-2009, 02:44 AM   #61 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
I would like to try this at some point. Lemme know if anyone is in a position to try it (not sure if the zener helps anything or not, maybe just a reverse diode would be better so the signal current isn't divided between the diodes but reverse impulses get absorbed).
Old 05-28-2009, 04:24 PM   #62 (permalink)
dcb
needs more cowbell
dcb's Avatar
Made a little progress, built the circuit (with reverse diode instead of zener) and tried it out on the bench. The standard guino would be showing about 0.53 gph but this is showing 0.77, so there may be some futzing yet as the opto may add delays and possibly innacuracies, but should be better than nothing.
There is an additional lead that should be connected to the plus side of the injector to eliminate variables.
Note: If I change inj delayUS to 1600 then it goes back to 0.53 gph, don't know if that is the correct course of action yet, just sayin.
Old 05-28-2009, 05:00 PM   #63 (permalink)
dcb
needs more cowbell
dcb's Avatar
Ok, It turns out I have a relative with a 93 s10 with a 4.3 tbi collecting dust in the garage. Hopefully that is a peak and hold too (sounds promising) I think I will have to arrange some in-person fidgeting...
Old 05-28-2009, 05:13 PM   #64 (permalink)
Active Learning - '93 Suburban Silverado
90 day: 10.67 mpg (US)
Everything I have ever read says that is a peak and hold injector. Should be very similar to what I have in the suburban. just smaller.
Old 05-28-2009, 07:54 PM   #65 (permalink)
nut
Coyote X's Avatar
Metro XFi - '93 Metro XFi Convertible
90 day: 62.17 mpg (US)
DR650SE - '07 DR650SE
90 day: 55.26 mpg (US)
Moonbeam - '94 Astro Conversion
90 day: 22.31 mpg (US)
Send a message via ICQ to Coyote X Send a message via AIM to Coyote X Send a message via MSN to Coyote X Send a message via Yahoo to Coyote X Send a message via Skype™ to Coyote X
the 93 S10 is peak and hold. Same exact setup as I have in my Astro
My Convertible Metro XFI Plug in Hybrid Project build log
Old 05-28-2009, 08:37 PM   #66 (permalink)
dcb
needs more cowbell
dcb's Avatar
Ok thx guys, now I just have to get the beast running
I got a haynes from the library (I love my library), and it "looks" like inj+ is connected to +12, so this might just be doable as a 4 prong deal using the "normal" connections, on a gm anyway.
Old 05-28-2009, 09:13 PM   #67 (permalink)
dcb
needs more cowbell
dcb's Avatar
Another data point
I hotwired inj+ to the 12volt lead and grabbed my guino splitter and a spare guino and plugged it all into the metro. When I changed injdelayUS on the guino attached to this gizmo to 1350 they were pretty much within 1% of each other on the gph display and turned over the hundreths place on a gallon at the same time.
Now it may be that peakers open quicker given their higher current, and that the number should come back down a bit too. Any stats on that?
Old 05-28-2009, 09:50 PM   #68 (permalink)
dcb
needs more cowbell
dcb's Avatar
Ok, here is an updated circuit. If anyone is following and wants to try it, feel free (It might take me a while). I would say make injUS delay at least 1000, or if you are coyotex, just dial it in with that diagnostic port
This goes in line with the injector lead, and the connector already has 12v and ground, and you should already have a negative injector tap.
Here is the opto I'm using:
http://mouser.com/Search/ProductDeta...key859-LTV-815
The diode is a 1n4004
http://mouser.com/Search/ProductDeta...lkey821-1N4004
The resistors are 10k ohm and 470 ohm
Old 10-07-2009, 10:46 PM   #69 (permalink)
Have you seen the Peak and Hold injector adaptor by JayCar?? They sell a kit that works with their duty cycle reader kit.
RIch
Old 01-03-2010, 08:57 PM   #70 (permalink)
in tents
dennyt's Avatar
The Adventure Wagon - '94 Loyale Wagon 4x4
Subaru
90 day: 33.43 mpg (US)
Electro-Monkey - '011 Karate Monkey BMC V2S Front Hub Motor
90 day: 694.1 mpg (US)
It looks like I'm facing this peak & hold challenge in my '94 Subaru Loyale SPFI. I get GPH readings that go up with engine RPM, but not throttle position - coasting vs. floored gives the same reading, only shifting changes the GPH.
Any recent developments, or should I dive in with this op amp circuit?
Pulse & Glide / EOC: Anyone rated their gallons per hour @ 0mph? dissimilation Hypermiling / EcoDriver's Ed 27 07-19-2010 03:12 AM
Slight error Johnny Mullet Forum News & Feedback 3 07-22-2008 04:05 PM
How Many Gallons Per Week? LostCause The Lounge 24 05-06-2008 10:02 AM
Tolls to limit rush hour driving? SVOboy General Efficiency Discussion 10 04-27-2008 04:12 AM
Fuel log error diamondlarry Forum News & Feedback 3 04-19-2008 03:38 PM
