I am sure you are all sick to death of hearing about HHO and I have read at length the previous posts here but what I propose draws from the following discussions:
http://ecomodder.com/forum/showthrea...ions-4618.html
http://ecomodder.com/forum/showthrea...ator-4705.html
http://ecomodder.com/forum/showthrea...mmm-10862.html
http://ecomodder.com/forum/showthrea...esel-9374.html
http://ecomodder.com/forum/showthrea...-hho-3798.html
All very interesting and similar debates discussed ALL OVER the web.
However I have not found one that discusses combining the two.
The complaints of HHO are due to the factors of energy conservation, (I will not go into it, read the above) but if one was to
use wasted energy generated from slowing your vehicle (braking) to charge a separate battery and the separate battery ran the HHO generator, then I do not see why this wouldn't work.
This guy really brakes down the Energy terms of the process:
Enough already with water-4-gas, hydro-assist and PICC... - Topic Powered by Social Strata
He says:-
"In reality, what you end up with is needing to output around 3150 kJ to keep the cycle going, but you are only producing 475 kJ. This is why water-4-gas did not work"
But again I am proposing to get that input of 3150kJ from wasted braking energy - or even solar backup.
-So deep cycle battery is charged during braking, and ticks over with 2.4W solar charger (£12.99 Maplin) if needed.
-Deep cycle battery continuously runs the HHO generator which uses the large 3150kJ energy from braking, stored in battery and produces small energy HHO 475kJ, which can be used effectively in the engine (there doesn't seem to be any doubts about that).
Put these into power:
3150kJ =875 Watt-hours
475kJ = 132 Watt-hours
Your basic car battery has about 1200 Watt-hours on a full charge.
If something uses 1 Amp, your car battery can run it for 100 hours. Something running at 20 amps will run 100/20=5 hours
I understand from asking suppliers of the big HHO kits that they pull from 10-20 Amps at 12V depending on how much electrolyte you use and how much you turn up your PWM.
I have confused myself here a little, but with all of the above figures it seems that a deep cycle battery would at least be able to produce HHO continuously for over an hour from a full charge. Then add the regenerative braking topping it up.
I am sure you brake a little bit on an hours journey... don't you??
I would appreciate any thoughts...
H
