Originally Posted by moonmonkey
do you have a belly pan?
do you have any results from your skirts
how wide are the skirts
are they one narrow peice or as wide as the tires?
Yes...I have a belly pan...
The only results I have from the side skirts are from the last few tanks of gas during my last run up north with winter gas and cold temps.
The skirts are 3/4" R-Matte foam insulation board. They are not as wide as the tires. There is about 4" (front) to 5" (rear) clearance from the ground with gear loaded in the truck and a full tank of gas. I plan to put some coroplast or luan over the top of the foam and maybe cut the ground clearance down to 2" or 3". Let the road determine the "adjustment factor".
