Old 01-28-2010, 01:38 AM   #14 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
Will - I was kinda thinking about bringing the Storm. If (and only if) I can get it to run on the stock engine using only two cylinders and run properly. I'm really thinking in the 40's at least with it.
If not, I actually thought about bringing the truck, too, if I can make it. I plan on doing some things to the Effwunfiddy anyway, and adding the MPGuino that I got from dcb for instrumentation. With the 6 cylinder, I see no reason I shouldn't be able to get decent numbers (disclaimer: for a truck that's 15 years old, running on an engine that was basically unchanged since the 60's.).
However, I'm going to need someone to bring something bigger than my truck for me to draft...
