Originally Posted by ECONORAM
Do you happen to own a repair manual? It should have a wiring diagram that will show you where the wire is. All my diesel time is on cars w/o electronics in the injection system, so I can't help you with the cam sensor location. You might see if there is an optical sensor near the camshaft pulley, or find a mechanic at the Peugeot dealer who will tell you.
Most of the time that I've seen, cam sensors are on the backend of the cam, or in the distributor.
