Old 01-28-2010, 02:15 PM   #5 (permalink)
orange4boy
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
Hi Ollie,
I want to do this with my Prius which has two coolant pumps. I have installed a 1500watt tank heater on the transaxle coolant lines and want to do it on the engine too. 1500 watts is too much. 750 would probably be about right.
I would like to heat up the heater core too so the inside is nice and toasty. That way I can justify the cost as part of my heating bill and the lady of the house is warm and happy too. I just have to hack the pump and install a manual switch.
To keep the heat in I have installed a thermal blanket over the engine and sealed off all gaps with foam tape. After an overnight soak at 5˚C the engine is still at about 12˚ This also helps keep the car warm when you stop to do an errand.
Those 400 watt block heaters were never meant for what we are doing.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
