Old 01-28-2010, 05:20 PM   #34 (permalink)
PaleMelanesian
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
Originally Posted by Old Mechanic View Post
Most efficient is low RPM and low vacuum.
1200-2400 with vacuum of 2 inches is pretty close on most engines for acceleration.
Throttle below 80%.
Pretty much. I'd trim the top end of the rpm range, to maybe 1200-2000 instead.
Throttle can be anything below where the ecu goes into open loop and enriches the mix. My standard target is 80% throttle, but always below the 95% open loop cutoff on my car.
In the original context - if you're having to choose between low vacuum (high MAP) and low rpm, you need to slow down. Then you can optimize both at the same time.
