Old 01-31-2010, 01:36 AM   #31 (permalink)
orange4boy
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
Some current accounting: NHW11
I just figured out the rough efficiency of the DC-DC but it's based on the headlights being 55 watts each.
As per the Graham scanner showing ~300V Low beams draw @ .51 Amps that's 153 watts. 55 x 2 = 110 watts leaving 43 extra watts. That works out to ~72% efficiency.
Other electrical loads. 2003 NHW11.
Running lights: .12 A / 36 watts
Headlights: .57 A / 171 watts high beams .51 A / 153 watts low beams.
Brake lights: .37 A / 111 watts
Rear defrost 1 A / 300 watts
Fan setting in amps: 1) .21 / 63 watts 2) .34 / 102 watts 3) .52 / 156 watts 4) .65 / 195 watts
Steering draws about 1A / 300 watts only while turning wheel, stopped, on gravel.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
