Old 02-01-2010, 09:01 AM   #15 (permalink)
Fubeca
The Truck - '06 Chevrolet Silverado Ext Cab 4x4
Originally Posted by Christ View Post
Can you weld? You either need to extend the spring pack's alignment pin by an inch, or you need to weld a new alignment pin onto your block and drill the spring side of the block for the pin that's already on the spring pack.
You could also just remove the overload spring, if you don't load your suspension up too much normally.
The easier option is to just buy a couple of alignment pins. They are pretty cheap and easy to come by.
Off Road Design makes a nice 1" block that bolts to the spring pack.
Add a Leafs, Zero Rate for 4x4 Suspensions from Offroad Design
