Old 02-01-2010, 01:01 PM   #14 (permalink)
90crxHF
Si engine and trans
90crxHF's Avatar
CRX Si/HF - '90 Honda CRX HF
90 day: 40.35 mpg (US)
Not going to be an issue in highway driving.
That's what you're setting this car up for, right?
Also the issue is more complicated that simple weight. Mass distribution of the 15's - more mass toward the outside - could potentially be less favourable than 13's or 14's. (Someone feel free to correct me on that - just something I read elsewhere that makes sense.)
Yes, I do like 90% highway with this car.
Oh and BTW, I got the 14x5.5" and I've already mounted them on the car. They fit great, now onto some Moon Eye covers...
I've found them online for like $85 for the stainless steel ones, anyone know of anything cheaper?
And BTW, Firestones on these wheels can take 44psi. What MPG difference would it make from 36PSI to the 44PSI? I guess only real world testing will tell, considering all the other variables... I try to drive as consistently as possible so my numbers are the least amount skewed....
Also, what size tire should I put back on these?? And if there is a 14" tire recommendation, please let me know. I've been looking at 175/70/14...
EDIT: There seems to be no difference in accelaration, and considering I don't drive fast anymore, it really doesn't matter....
~1990 Honda CRX HF - ZC SOHC 1.6L non-VTEC, Si trans, Illuminas, Neuspeed Race
1/8th: 9.90 @ 71.03, 60' - 2.41 (HMP '08) - 284K on chassis and ~110k on engine
~1996 Mustang GTS/248A - 1/4: 13.447 @ 99.75, 60' - 1.820 (HRP - 959' DA)
http://www.nearlysurrounded.com <-- Check out my band
