Originally Posted by Christ
Lowering the rear will be the easiest option, since it could really be done with just about anything that's fairly strong. An aluminum block would work, but you'd have to check it from time to time to make sure that the u-bolts stay tight.
I was saying material foe the air dam.
I will need new tires soon, the old ones are 245/ 70 16. I was thinking a slightly taller and narrower tire, but still a road tire.
