Originally Posted by dcb
I would unplug all the injectors at the same time in that case and see if one of the two leads going to the injector
Oh, is that what you mean? Ive been testing both leads going in (with voltmeter + on one lead and - on the other lead = 12v).
So what i should be doing instead is (- on chassis ground, then use + to see which one of the two wires coming in is 12V?)
