Old 02-02-2010, 03:51 PM   #22 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
I just noticed that the track width isn't that much wider than on the CRX... I'd have (and did) guess otherwise, as I noted in the PM.
1.6cm is usually within the stretchable realm for axles, but if you can get the wider ones, that might be an even better fit for you, because they don't like to be stretched beyond a certain point and still function properly.
This is exciting.
