Old 02-02-2010, 01:21 PM   #21 (permalink)
Si engine and trans
90crxHF's Avatar
CRX Si/HF - '90 Honda CRX HF
90 day: 40.35 mpg (US)
I want the HF transmission, mainly for the 5th gear...
~1990 Honda CRX HF - ZC SOHC 1.6L non-VTEC, Si trans, Illuminas, Neuspeed Race
1/8th: 9.90 @ 71.03, 60' - 2.41 (HMP '08) - 284K on chassis and ~110k on engine
~1996 Mustang GTS/248A - 1/4: 13.447 @ 99.75, 60' - 1.820 (HRP - 959' DA)
http://www.nearlysurrounded.com <-- Check out my band
Old 02-02-2010, 02:51 PM   #22 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
I just noticed that the track width isn't that much wider than on the CRX... I'd have (and did) guess otherwise, as I noted in the PM.
1.6cm is usually within the stretchable realm for axles, but if you can get the wider ones, that might be an even better fit for you, because they don't like to be stretched beyond a certain point and still function properly.
This is exciting.
Old 02-02-2010, 03:36 PM   #23 (permalink)
Wonderboy's Avatar
The Fruit Bat - '01 Honda Insight
Last 3: 54.26 mpg (US)
Current - '21 Subaru Impreza Wagon
90 day: 34.36 mpg (US)
Originally Posted by Gasoline Fumes
If you need longer axles, the 1995+ Metros have them. The track is 0.8" wider on the newer cars.
That's actually the measurement I cited, not my XFi's track width. The '95+ track width number was all I could find in my quick search, so the 2nd gen CRX's track (1400mm) is 1.6cm wider than 3rd gen suzukiclones (1384mm). I just figured the track didn't change over those generations
Based on how wiggly axles feel to be, I don't think that 1.6cm/2 is going to be much of a stretch for axles to handle. Does anyone know for sure one way or another that stretching one axle 8mm farther than its used to could cause significant safety or longevity concerns?
90crxHF: If you want that transmission and it's actually still there, I'd be happy to get it for you if you pay for it and its shipping. PM me if you're serious, but I'd be looking locally if I were you. Shipping could get pricey.
Old 02-02-2010, 03:46 PM   #24 (permalink)
8mm = .31 inches. It's within the normal variation for engine mount movement, so I don't see a problem with it.
The one issue that could arise is with suspension travel, but that's not likely either.
Axles tend to have 1" or more of movement in both directions at both ends from center, so there's alot of "wiggle room" in them.
Make sure you check/replace the front suspension bushings on the Civic, though, becuase if you don't, you'll ruin axles on a weekly basis. Ask me how I know... LOL.
The axles that I have that are new in the box are the 5th warranty replacement before I could figure out what the problem was.
Old 02-02-2010, 04:00 PM   #25 (permalink)
Wonderboy's Avatar
You've ruined my "suspension travel" aspirations. I was going to surprise everyone too.
Old 02-02-2010, 04:01 PM   #26 (permalink)
LOL. Did you get the PM about the knuckles?
Old 02-25-2010, 07:32 PM   #27 (permalink)
Wonderboy's Avatar
So let's just say I found a gen 1 CRX shell in great condition for sale locally with the right price ... because I did.
I'm trying to compare the benefits of the reduced weight of an oldie (an 86) with its slightly worse aerodynamics and Macpherson struts (vs. the double wishbone suspension of a gen 2 CRX). Can anyone chime in to help me assess how important weight is versus aero + double wishbone suspension (fierce cornering ability is important when trying to conserve kinetic energy around curves). I'm really teetering on this, ever so slightly leaning toward holding out for a gen 2, since I'm not really in much of a hurry.
Old 02-25-2010, 07:52 PM   #28 (permalink)
ecomonkey
silver clown - '02 toyota echo 2 door base
90 day: 47.16 mpg (US)
white ghost - '05 prius base
90 day: 47.53 mpg (US)
white pearl - '12 toyota prius base
Last 3: 45.69 mpg (US)
weight is alot less important if you do alot of highway driving, aero is more important at higher speeds and weight is less important if you dont have to slow way down or stop alot,, it doesnt hurt much at constant speeds,, from my experience's.
Old 02-25-2010, 09:04 PM   #29 (permalink)
90 day: 51.82 mpg (US)
The Gen 1 may have a slightly higher Cd (guessing), but I bet it also has a smaller A. CdA is the thing, remember, and it's easier to reduce Cd than A.
Buy it!
Old 02-25-2010, 10:15 PM   #30 (permalink)
Wonderboy's Avatar
According to our handy-dandy Cd list in the Wiki section:
Honda CRX 1984 - 1987 0.32Cd | 18.3sq.ft | 5.84CdA
Honda CRX 1988 - 1991 0.30Cd | 18.6 sq.ft | 5.57CdA
Honda CRX HF 1988 - 1991 0.29Cd | 18.6sq.ft | 5.39CdA
Whipping out the ol' calculator tells me that the Gen1 only has 3.6 sq. inches less frontal area than Gen 2, correct? That wouldn't seem like something to shake a stick at to me - less than a passenger mirror for sure. I'd just as soon assume for this argument that Gen1 and 2 have the same frontal area......decisions!
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 158 01-12-2013 11:59 AM
Seriously! My 1994 Honda Civic DX Build Thread! JJMunoz EcoModding Central 29 02-18-2012 08:09 PM
Geo Metro XFi cam swap How To Johnny Mullet DIY / How-to 13 01-31-2012 09:05 AM
Geo Metro XFI Convertible Project Finished Coyote X EcoModding Central 227 11-14-2009 10:31 PM
Starting to Mod my Xfi bbjsw10 EcoModding Central 140 04-14-2009 07:27 AM
