Originally Posted by Bow
Hmmm
I'll have to figure out how to do the taper...
Good idea, thanks
Fit it to the frame and to the bed side, then push on the top corner until you get approx 12*.
Either that, or just angle it in 12* and leave the bedside as a flat plane.
Side flow follows the approximate same rules as top flow, as far as I'm aware, in most situations, so the same basic angles apply. It's the bottom that gets tricky..
