In the old days when we suspected an ignition problem that was intermittent, we would wrap a piece of wire around one of the plug wires and the other end around the radio antenna.
The static noise would give you an indication of ignition function, and if the ignition died the noise would either drop a lot or go away altogether.
regards
Mech
