Old 02-04-2010, 06:56 PM   #24 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
How about a quickie duct-tape and coroplast test of the green line? You could add some vertical supports underneath the outer edges down to the bumper bulge. That and the curvature of the trunk should make it stiff enough.
EDIT: Aerohead beat me to the post but I think we had the same idea about the side pieces. He said it much more eloquently.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
