some alternators are one wire everything is inside
but most energize through the light or resistor if the light burns out or by the computer, on the first alternators if the light burned out they quit charging.
"Has anyone safely used this method (for turning off alternator, manually or auto) and what is the avg current of said field. Link to switch again and THANKS!!"
it wouldn't hurt the alternator, what about all the electronic else where?
if i put a 140 amp alternator on the drive shaft, that's over 2 HP, i will feel that baby when i hit the regen button.
