Old 03-25-2008, 01:14 AM   #35 (permalink)
AmpEater
Originally Posted by diesel_john View Post
is that tranny direct drive in fourth?
Year, forth is 1:1
I like the idea of using a smog pump as a turbine basically. I've heard of them being used similarly in solar hot water setups to drive a generator, so they must be pretty tough. I've got a couple GAST air motors, rated 6hp cont at 100psi and like 10+ cfm 3000rpm. I wonder if they would make for a decent generator turbine. Probably not designed to run with a hot gas input.
