Old 02-07-2010, 05:52 PM   #1 (permalink)
Oval_Overload
24.27 lbs per gallon Co2
Oval_Overload's Avatar
Unicorn - '12 Nissan Versa 1.8S hatch
90 day: 31.9 mpg (US)
Anybody familiar with 220 wiring?
I need to wire a socket on the outside of my house for an EV charger. 20 amps at 220 volts. From what I have gathered, I need to run 12-3 gauge wire through a 20 amp ganged breaker to a weather proof box with a weather-proof -at-all-times cover. My hang-up here is code states that circuits that may come in contact with moisture must be GFCI protected. Does this apply to 220 volt?
~Jimbo
Hehehe... If one of your facial lacerations leaves a small scar, you'll have a SCarlett.
