Old 02-07-2010, 05:59 PM   #2 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
Originally Posted by Oval_Overload View Post
I need to wire a socket on the outside of my house for an EV charger. 20 amps at 220 volts. From what I have gathered, I need to run 12-3 gauge wire through a 20 amp ganged breaker to a weather proof box with a weather-proof -at-all-times cover. My hang-up here is code states that circuits that may come in contact with moisture must be GFCI protected. Does this apply to 220 volt?
~Jimbo
Technically, you'll have to have it inspected anyway... why not ask the code inspector?
Usually, you can get a hold of your local code enforcement and ask these types of questions, and they're more than happy to answer over the phone. Construction/updating codes will be different for people who don't live in your state/county/town.
Around here, we use the PA UCC, but some local towns have rejected it, and have their own construction/installation code that is above and beyond the Universal Construction Code.
